TFT Display nachrüsten
Diskutiere TFT Display nachrüsten im R 1200 GS LC und R 1200 GS Adventure LC Forum im Bereich Motorrad Modelle; My RX-5 should be delivered within the next few days. In preparation, I've done a diagnostic scan with the GS-911 and the report showed No...
Ron_from_BC
Ron_from_BC
Vancouver Island, BC Canada
2017 R1200GSA
My RX-5 should be delivered within the next few days. In preparation, I've done a diagnostic scan with the GS-911 and the report showed No Faults. I also made a note of the Service Reminder mileage I created when I last changed the oil, the range based on my gas and the odometer to see if the Koso correctly shows this data after the install.
Ron_from_BC
Ron_from_BC
2017 R1200GSA
Installed the RX-5 today and completed a diagnostic scan. It's showing the same fault codes as it did when they recalled them. Two ABS faults and two Engine Controller faults all because the bike main computer does not recognize the RX-5 as the original display.
I'm also having some difficulty navigating through the different screens but that could be my problem. Not sure if I want to keep it or not yet.
Erich1964
Erich1964
Östliches Ruhrgebiet
R 1200 GS LC ADV.
Is the ABS out of order, or is "only" an error displayed?
I can't wait to see what KOSO has to say!
arnd05
arnd05
ruhrpott
Hello Ron,
Have the displayed errors been deleted in the meantime? If not, then it is completely normal for them to be displayed.
And how do you know that the errors are caused by the replaced display? Is this displayed anywhere???
My RX 5 doesn't show any of these abnormalities...
....and after 2-3 successful attempts the operation is quite problem-free, you just have to get used to it a bit....
Ron_from_BC
Ron_from_BC
2017 R1200GSA
Hello Ron,
Morning,
The errors are not seen on the RX-5 display they are only shown during a diagnostic scan as is done when at the dealer. I completed a scan just prior to the RX-5 install the there were no Fault Codes in the system however immediately after the RX-5 was installed the scan showed the 4 Fault Codes. These are the identical codes that were present last year which prompted the recall. I can clear the codes however when the bike is restarted the fault codes are again shown.
I've sent an email to Koso with these concerns and would expect to hear something from them later today. A copy of the email went to their technician. I can also forward a pdf of the before and after scan I completed on the bike.
Ron_from_BC
Ron_from_BC
2017 R1200GSA
I didn't do a road test on the bike however last year during the initial release of the RX-5 another rider received these same faults on his bike. He did ride the bike and the ABS was still working despite the errors from the bike's main computer during a scan.
The problem is if you were to be involved in an accident and law enforcement or the insurance company did an inspection on the bike and found that there were these fault codes present on your bike I'm not sure they would say 'No problem' they are just errors that show up on a diagnostic scan.
oguhei
oguhei
Wenn ich das auf der verlinkten Seite richtig verstanden habe, ist das ein Prototyp der 2019 auf der Messe vorgestellt wurde.
Uli G.
Uli G.
Hannover
sollten wir nicht bei der deutschen Forumssprache bleiben, ich verstehe da einiges nicht wirklich, translste kann auch nicht alles
Schon mal geschaut, woher Ron kommt?
BC = British Columbia in Kanada, ungefähr 3/4 der Einwohner sprechen englisch ;).
Uli G.
Uli G.
Hannover
Was hat das bitte mit dem Umstand zu tun, dass wir hier in Deutschland sind und in einem deutschen Forum?
Weil Ron englisch spricht, darf er nicht im Forum sein und posten?
Weltoffene BMW-Treiber :confused: :eekek: (die hoffentlich niemals über deutsche Grenzen hinaus in fremdsprachige Länderfahren und dort unangenehm auffallen, weil sie nur Deutsch können :().
Mike1300
Mike1300
Wuppertal
R1200 GS LC Adventure
Ich und viele andere können sicherlich nur die Hälfte von dem gekritzel lesen.
Ausserdem habe ich gar keine Lust das zu lesen, ansonsten würde ich mich in einem Englisch sprachigen GS Forum anmelden und nicht hier in Deutschland!
Vielleicht kannst du das einfach mal akzeptieren, so viel zum Thema Weltoffen und Toleranz
Uli G.
Uli G.
Hannover
OT
Das Forum heißt GS-Forum.EU!
Schon mal geschaut, wieviele nicht deutschsprachige Länder zu Europa gehören?
Und Text in einer (dir nicht geläufigen Sprache) als Gekritzel zu bezeichnen, ist ziemlich stark daneben :facepalm: . Sei froh, daß du hier deutsch sprechen darfst. (btw:. (Anglizismus ;)) "Es sollte "Viele andere und ich ..." heißen. Merkspruch meiner Großmutter: "Nur der Esel nennt sich immer zuerst" :)).
OTE
Zurück zum Nachrüsten des TFT
Ron_from_BC
Ron_from_BC
2017 R1200GSA
Ich entschuldige mich, wenn mein Beitrag dieses Thema verwirrt oder abgelenkt hat. Meine Absicht war es, andere Erfahrungen zu diesem Thema einzuholen und auch die Erfahrungen anderer in Nordamerika bereitzustellen, die dieses Produkt verwendet haben, und so bei der Lösung etwaiger Probleme zu helfen. Ich habe für meine Kommentare auf Google Translate zurückgegriffen, die oft nicht korrekt, aber besser sind als das, was ich gelernt habe, als ich einige Zeit in Deutschland beim Skifahren im Harz im Norden und Sonthofen im Süden und an vielen anderen Touristenzielen verbracht habe.
Ich freue mich darauf, weitere Erfahrungen mit dem RX-5-Display zu lesen. Fahre sicher.
via Google Translate
Uli G.
Uli G.
Hannover
There is no need to apologize :).
MysticHealer
MysticHealer
Bremen
BMW R12
Stimmt wohl. Obwohl es mit dem GoogleTranslator anscheinend auch gut funktioniert.
Zur Endung .eu:
Die sagt erstmal gar nichts aus, solange man nicht mit Gewissheit weiß, dass diese vom Webmaster aus den von dir genannten Gründen bewusst so gewählt wurde, um alle GS-Fahrer in Europa zu einen. Oder aber die Domain mit .de war einfach nur bereits vergeben… :schulterzucken:
Jomar59
Jomar59
BMW R 1200 GS LC BMW F 900 XR
mir ist nur aufgefallen, wenn jemand italienisch etc schreibt von der Obrigkeit darauf aufmerksam gemacht wird, dass die Forumssprache deutsch ist, warum das dann bei englisch nicht so ist? Entweder mache ich das bei allen odrr keinen. Canada spricht auch viel französisch, wenn ich das nun mit translate ins englische und dann ins deutsche ....
Erich1964
Erich1964
R 1200 GS LC ADV.
Um mal wieder zum eigendlichen Thema zu kommen, und dieses überflüssige
Gelaber zu beenden!!!
Ich hab Gestern die erste Runde nach meiner Schulter OP und mit dem neuen Display
gemacht. Also er macht alles was er soll, die Anzeigen rechts könnten etwas
Grösser sein aber man gewöhnt sich daran!
Die Bedienung ist reine gewohnheit, ich finde es gut so!
Sicher kann man das eine oder andere aufhübschen, aber man muss
sich im klaren sein das, das Original 330€ mehr kostet und auch nicht
mehr kann.
TFT Display nachrüsten - Ähnliche Themen
  • "EINSTÈLLUNGEN"auf TFT Display
    "EINSTÈLLUNGEN"auf TFT Display: Für was ist eigentlich die Rubrik Einstellungen im TFT Display? Es existiert zwar aber Einstellen kann ich nix. Was mach ich falsch? Kraichgauer
  • USB Steckdose neben dem TFT Display
    USB Steckdose neben dem TFT Display: Tach zusammen, hat sich jemand schon mal eine separate USB Steckdose neben dem TFT geschraubt und wenn ja, wie war die Installation? Die...
  • TFT Schutzfolie wechseln
    TFT Schutzfolie wechseln: Auf meinem TFTs habe ich immer auch eine Schutzfolie. Vorteil 1: Keine Kratzer auf dem TFT, gut für den Wiederverkaufswert. ("Saharasand -...
  • TFT Display bei 750 GS nachrüsten?
    TFT Display bei 750 GS nachrüsten?: Ich fahre eine GS 750 mit dem Baujahr 2020, die ein Rundinstrument als Drehzahlmesser und einen Tachometer mit LED Anzeige hat. Weiß jemand von...
  • BMW Connectivity/ TFT Display - Nachrüstung?
    BMW Connectivity/ TFT Display - Nachrüstung?: Hallo, da es ja für die 2017+ eine Möglichkeit der Nachrüstung gibt, wäre interessant, was man alles für alte Modelle braucht zb 2015+ Im...
  • BMW Connectivity/ TFT Display - Nachrüstung? - Ähnliche Themen
