2025 CFMOTO 800MT-X
(KTM 790ADV-R Zwilling)
https://motoink.com.au/product/2025-cfmoto-800mt-x-my25-edition/
starting AUD$13790 (~8400 Euro)
2025 CFMOTO 800MT-X MY25 HAS ARRIVED
* FREE $800 CFMOTO RIDERS PACK: JACKET, HELMET, GLOVES & FIX PRICE SERVICING FOR 3 YEARS.
(LTD TIME ONLY WHILE STOCK LASTS EXCLUSIVE TO MOTOINK).
AUSTRALIA WIDE DELIVERY FROM ($150 VIC METRO)
The 800MT-X features an updated version of the KTM-derived LC8c 799cc parallel twin engine, optimised by CFMOTO for adventure riding with more torque and refined performance:
• 87Nm @ 6750rpm: 11Nm more than previous iterations, with peak torque shifted to lower in the rev range.
• 70kW/95hp @ 8500rpm: Retained power for strong mid-to-high RPM performance.
• Equipped with twin balancer shafts for minimal vibration, enhanced electronic fuel injection, and DLC noise-reducing coating technologies.
ENHANCED FOR OFF-ROAD ADVENTURES
The 800MT-X is built for rugged terrain and long-distance travel. Lightweight yet durable, it offers superior stability and handling:
• 21”/18” spoked aluminium rims with tubeless adventure tyres.
• 240mm ground clearance and adjusted rake/trail for balanced road and off-road performance.
• 15.1kg lightweight frame and sub-frame designed for carrying passengers and luggage.
• Lowered saddle-shaped fuel tank for better stability and rider confidence.
BEEFY SUSPENSION
Serious off-road riding capability is ensured with high-quality adjustable suspension:
• YU’AN 48mm USD front fork with 230mm travel, fully adjustable for preload, compression, and rebound damping.
• YU’AN single piggyback rear shock with 230mm travel, fully adjustable with preload adjuster.
READY FOR LONG JOURNEYS
The 800MT-X is adventure-ready with features that maximise comfort and convenience.
• 22.5L fuel tank
• Cruise control for reduced rider fatigue.
• Three riding modes: Standard, Rain, and Off-road.
• One-piece rally-style seat, adjustable windscreen, tyre pressure monitoring, and LED lighting.
• Easy-access air filter.
ADVANCED RIDER AIDS
The 800MT-X features state-of-the-art technology for safety and performance:
• Bosch 6-axis IMU for cornering ABS and traction control.
• Quick shifter (bi-directional), power-assisted slipper clutch, and steering damper for confident handling.
• 7-inch vertical TFT display with Bluetooth and T-BOX connectivity via the CFMOTO RIDE app.
The 800MT-X features switchable traction control for optimal grip across varying terrain, while the advanced cornering ABS system allows the rear wheel to be deactivated for enhanced control and confidence in off-road conditions.
Engine
Engine Type: Liquid-cooled, fuel-injected, DOHC, four-stroke parallel-twin, 285° crankshaft
Capacity: 799cc
Bore & stroke: 88mm x 65.7mm
Compression ratio: 11.5 :1
Fuel system: Bosch EFI
Maximum power: 95hp (70 kW) at 8,500rpm
Maximum torque: 87Nm at 6,750rpm
Gearbox: Six-speed with power-assisted slipper clutch (PASC) & bi-directional quickshifter
Ride modes: Standard, Rain, Off Road
Chassis
Frame: Tubular steel frame
Front suspension: YU'AN Ø48mm USD fork, fully adjustable, 230mm travel
Rear suspension: YU'AN single rear shock, fully adjustable, 230mm travel
Front brakes: J.Juan 4-piston radial calipers, dual Ø320mm floating discs
Rear brakes: J.Juan twin-piston caliper, Ø260mm disc
ABS: BOSCH Cornering ABS, rear-wheel switchable for off-road use
Traction control: BOSCH traction control (Switchable)
Wheels/Tyres
Wheels: Wire-spoked
Front tyre: 90/90 R21
Rear tyre: 150/70 R18
Size / Weight
Wheelbase: 1530mm
Length x width x height: 2288mm x 945mm x 1426mm
Seat height: 870mm
Ground clearance: 240mm
Fuel capacity: 22.5L
Weight: 200kg Dry / 220kg Kerb
Colour: Nebula Black or Zephyr Blue
Warranty: 3 Year Warranty
J.Juan brake systems = Brembo China
https://jjuan.com/en/about-us/
