Hilfe!
Diskutiere Hilfe! im 2 Ventiler Forum im Bereich Motorrad Modelle; Sorry, I meant the little bypass valve that sits just inside of the filter. According to the book, if this valve is stuck in open position and/or...
N
Norwegian
Sorry, I meant the little bypass valve that sits just inside of the filter. According to the book, if this valve is stuck in open position and/or does not seal properly, then it can lead to low oil pressure. But I find it hard to understand, because all the fluid will still have to pass trough the same "bottleneck" before it reaches the pressure switch. If the pump delivers the correct amount of flow, then pressure would have to build up again after passing the bypass valve (if it is open)?
By the way; is the outer rotor on the pump secured by a .....? I cannot find it in any spares list or shops.
The bike is parked now. I have contacted a German BMW mechanic who will fix the bike when he gets back from vacation.
it still runs fine and the are no strange sounds. In the end, before I parked it, the oil lamp went off again and acted normal except for same vague glow when I accelerated.
Hallo Norwegian,
Schau mal hier: Hilfe!. Dort wird jeder fündig.
N
Norwegian
Looks like a word fell out?
Is the outer rotor secured by a small threaded/countersunk bolt?
blackbeemer
No, the outer roter runs free.
The bypassventil is only working for the filter, wenn this is open, the filter will not work, but the oilpressure must be ok.
Try this too: throw down the cable from the oilpressureswitch and turn the ignition on. If the lamp will glow now, ist only an electric problem.
Hilfe!
Hilfe! - Ähnliche Themen
  • Erste-Hilfe
    Erste-Hilfe: Hi Hand auf's Herz: Hat noch jeder Ahnung wie das mit der Herz-Lungen-Wiederbelebung war (und aktuell ist), wie eine stabile Seitenlage...
  • Hilfe bei Krümmer
    Hilfe bei Krümmer: Hey Leute, Ich hab heute von einem Kumpel ein Moped gebracht bekommen um ihm bei seinem Auspuff bzw Krümmer zu helfen. Er hat mir die Maschine...
  • Hilfe benötigt: Fahrwerk einstellen R1200GS K25 - Region West-Berlin und Umgebung
    Hilfe benötigt: Fahrwerk einstellen R1200GS K25 - Region West-Berlin und Umgebung: Gemeinde, ich habe mir jetzt wirklich einige Videos angesehen und herumgelesen, was die Einstellung des Fahrwerks der GS betrifft. Einer sagt das...
  • Hilfe: RDKS Sensoren melden sich nicht an nach Radwechsel
    Hilfe: RDKS Sensoren melden sich nicht an nach Radwechsel: Hallo zusammen, habe soeben meinen neuen Radsatz an der 1250GSA (BJ 2022) montiert. Hat soweit alles geklappt, nur habe ich es nicht geschafft...
  • Hilfe zur Fertigstellung einer Yamaha XT500 (PLZ 96xxx / 90xxx)
    Hilfe zur Fertigstellung einer Yamaha XT500 (PLZ 96xxx / 90xxx): Hallo zusammen, nun kommt ein etwas spezieller Aufruf ... Seit Jahren schlummert mein XT500-Projekt in der Werkstatt. Vieles daran ist mechanisch...
  • Hilfe zur Fertigstellung einer Yamaha XT500 (PLZ 96xxx / 90xxx) - Ähnliche Themen
  • Erste-Hilfe
  • Hilfe bei Krümmer
