FlowRider
Moderator
- Dabei seit
- 02.02.2019
- Beiträge
- 10.841
- Modell
- GS (poly)
Sehr ... originell. Für 75.000 US-Dollar.
https://www.curtissmotorcycles.com/design
Motor
YASA P400 R Series
Peak Output
217 HP
Continuous Torque
147 LB-FT
Battery Capacity
16.8 kWh at 399V
Chassis
1.75” Titanium or Chromoly tubular hand welded and machined 6061 aluminum fusion
Suspension
Front:
Double-wishbone parallelogram fork with machined 6061 aluminum girders and direct-action, race-proven RaceTech monoshock, fully-adjustable for high and low speed compression and rebound damping, 6” of travel
Rear:
Machined 6061 aluminum swingarm with centerline RaceTech monoshock offering two-speed compression and rebound damping, 6” of travel
Inverter
Cascadia Motion PM100 Propulsion Inverter
Head Angle
27 Degrees
Wheelbase
63.5”
Ground Clearance
9”
Seat Height
28”
Brakes
Front:
4 X 230 MM Beringer floating aeronal cast iron discs with four-piston Beringer radially-mounted Aerotec calipers
Rear:
2 X 230 MM Beringer floating aeronal cast iron discs with four-piston Beringer radially-mounted Aerotec calipers
Wheels / Tires
Front:
110/80 R18 on BST Carbon Fiber Wheel
Rear:
160/60 R18 on BST Carbon Fiber Wheel
PRICE
75,000 USD
Motor
YASA P400 R Series
Peak Output
217 HP
Continuous Torque
147 LB-FT
Battery Capacity
16.8 kWh at 399V
Chassis
Suspension
Front:
Rear:
Inverter
Head Angle
27 Degrees
Wheelbase
63.5”
Ground Clearance
9”
Seat Height
28”
Brakes
Front:
Rear:
Wheels / Tires
Front:
Rear:
PRICE
75,000 USD
