GS-911 Update
Diskutiere GS-911 Update im Technik & Bastel-Ecke Forum im Bereich Modellunabhängige Foren; Hex GS-911 --> OCTOBER 2024 SOFTWARE AND FIRMWARE UPDATES DETAILS: GS-911 Diagnostics v2410.2 GS-911WiFi Firmware v300; Datapack v282...
Frank_Pfalz
Frank_Pfalz
Vorderpfalz
DETAILS:
Here’s what you can look forward to:
  • Sporty Instrument Features: Owners of BMW bikes with the XKOMBIHI Instrument Cluster, like the R1250 GS/GSA, can now configure some sporty instrument features on their BMW adventure models—features usually found on sportier BMW bikes. For example, you can now activate the Shift Light, adding a dynamic, sporty feel to your ride.
  • Enhanced Navigation: You can now enable your XKOMBIHI instrument cluster, to use the BMW Connected app.
  • Easy Troubleshooting: If you come across a fault code during an autoscan, you can now click on helpful quick links (while connected to the internet) to access a troubleshooting page on the HEX server. This page will describe the likely symptoms and causes, along with suggested steps to resolve the fault.
  • Service Reminder Customisation: We’ve expanded service reminder support to more models, including the R12 and CE02. This makes it easier to reset service reminders yourself.
  • WiFi Connection Alerts: If the WiFi connection fails, you’ll now hear a long beep, along with a red LED light, so you’ll know right away.
  • Support for More Models: Added features for BMW Nav Prepare Retrofit/Remove and expanded support menus for models like the CE02, R12, R12 nineT, R1300GSA, 2021 G310, and 2022 C400.
  • Improved Downloads: ECU links are now included in downloaded autoscans and PDFs, making it quicker to navigate within the files
  • Better Controller Management: The autoscan now checks for missing controllers and provides warnings if something expected isn't detected.
  • New Network Test Panel: Available in the PC Diagnostics App for easier connectivity testing.
QUELLE
P
PropellerAtze
Nürnberg
R 1250 GS
als kleiner Anhang, meins wurde letztes Wochenende eines Updates unterzogen und es geht schon wieder weiter
GS-911 Software 2410.3
GS-911WiFi Firmware 2.56 -0.300, Datapack V 283
Frank_Pfalz
Frank_Pfalz
Vorderpfalz
JANUARY 2025 SOFTWARE AND FIRMWARE UPDATES
SOFTWARE UPDATE DETAILS:
  • GS-911 Diagnostics 2501.4 -----------------> (2025-03: 2502.3)
  • GS-911WiFi Firmware v304; Datapack v291
Customise Your XKOMBIHI Display
Lithium Battery Health Monitoring
Enable & Disable the Alarm with Your Keyless Fob
Seamlessly Integrate Alarms and Tyre Pressure Controllers
Tyre Pressure & Temperature Monitoring for More Bikes
New 2024 BMW Models Added
Autoscan Menu Enabled by Default
Improved Autoscan Progress Display
GS-911 Update
GS-911 Update - Ähnliche Themen
  • Erledigt Diagnosegerät: GS-911 WIFI 10-Pin Enthusiast 10 VIN inkl. Adapter
    Diagnosegerät: GS-911 WIFI 10-Pin Enthusiast 10 VIN inkl. Adapter: Ich verkaufe das o. g. Diagnosegerät mit USB- und OBD-II-Anschluss. Eine VIN ist bereits „verbraucht“, es stehen noch neun weitere VIN zur...
  • Biete Sonstiges GS-911 Wifi OBD u. HEX ezCAN
    GS-911 Wifi OBD u. HEX ezCAN: Moin, ich biete an: GS-911 Wifi OBD, FP 345,00 € (zzgl. Versandkosten DHL) HEX ezCAN für R1200 LC...
  • Suche HEX GS 911 Diagnosegerät
    HEX GS 911 Diagnosegerät: Suche GS 911 OBD2 USB oder WIFI
  • Suche Suche GS 911 Diagnosegerät GS-911 WiFi-Version OBDII
    Suche GS 911 Diagnosegerät GS-911 WiFi-Version OBDII: Hallo Zusammen, ich suche für meine 1250 GS 2020 das folgende gebrauchte Diagnosegerät. Diagnosegerät GS-911 WiFi-Version OBDII Viele Grüsse...
  • Erledigt HEX GS 911 USB Diagnosegerät
    HEX GS 911 USB Diagnosegerät: Hallo, ich verkaufe ein HEX GS 911 USB Diagnosegerät. Ich brauche es nicht mehr, tatsächlich habe ich es auch nur wenige Male benutzt. Es ist die...
  • HEX GS 911 USB Diagnosegerät - Ähnliche Themen
