Garmin Basecamp 4.0.2 verfügbar
Diskutiere Garmin Basecamp 4.0.2 verfügbar im Navigation Forum im Bereich Modellunabhängige Foren; zum Update auf Hilfe, dann auf "nach Software-Updates suchen" klicken.
J
jonnyy-xp
DeHess
DeHess
MTK
GSA 1200 TB
Super! Danke für den Hinweis.:rocker:
Anbei die Changehistory
Changes made from version 4.0.1 to 4.0.2:
Added smoothing of speed and heart rate graphs.
Improved Track Join inside of an Adventure
Change to not show the 'Filter Results' option in the find results if there are no results to filter.
Fixed layout not being remembered properly between application runs.
Fixed an issue with some card products not being recognized. Unfortunately this requires re-indexing all card products.
Fixed layout being different after exiting from Adventure playback.
Fixed an issue with the 'References' tab page not being properly updated when changing selection.
Fixed an issue with route shaping point info being lost when erasing points from a route.
Fixed an issue with track color being changed when tracks are filtered.
Fixed an issue with not updating the summary in the route dialog when points are unselected.
Fixed some issues with login and re-login for MyGarmin services
Fixed doing an undo while drawing a route ending the route. Now only the last via point is removed.
Fixed an issue when importing photos with invalid time EXIF data.
Fixed text messages from Basestation devices being repeatedly notified
Fixed an issue with route join
Fixed an issue with the route divide tool
Fixed an issue with duplicating routes
Fixed an issue with adding waypoints into routes in an Adventure
Fixed an issue with line breaks being repeatedly added to GPX files
Fixed an issue with click & drag on the map hiding properties dialog
Fixed an issue with importing KML or KMZ files that had downloadable content.
Fixed an issue with creating a waypoint via the map context menu when a list folder is selected
Fixed an issue where the waypoint ordering was not updated when changing the main track in an Adventure
Fixed an issue when clicking on the 'X' to remove a tag from the References tab page.
Fixed an issue when changing map detail level before putting focus into the map views.
Fixed an issue where the creation date of a photo waypoint didn't match the creation date of the photo's EXIF data
Fixed an issue with waypoints sometimes not being shown on the map
Changes made from version 3.3.3 to 4.0.1:
Added Garmin Adventures, including; authoring, publishing, online search, downloading, playback, and transfer to supporting devices.
Garmin Basecamp 4.0.2 verfügbar - Ähnliche Themen
  • Garmin Zumo XT vs Basecamp Diskussion (ausgelagert)
    Garmin Zumo XT vs Basecamp Diskussion (ausgelagert): Info Mod: Diskussion über Basecamp wurde auf Wunsch von der XT versus XT2 Diskussion ausgelagert Der XT2 kann nicht mehr (richtig) mit Basecamp...
  • GARMIN ZUMO XT in Verbindung mit BASECAMP auf WIN11
    GARMIN ZUMO XT in Verbindung mit BASECAMP auf WIN11: Hallo Forumisti, irgendwie steh ich auf dem Schlauch. Ich habe mir auf meinen neuen WIN11 PC Basecamp heruntergeladen und wollte die Karten auf PC...
  • Garmin Basecamp Wintersperren ignorieren
    Garmin Basecamp Wintersperren ignorieren: Hallo, was macht man an so nassen Wintertagen ? Natuerlich für den Sommer planen. Leider macht Basecamp nicht so wie ich möchte und umfährt viele...
  • Import in Garmin Zumo funktioniert nicht aus Basecamp
    Import in Garmin Zumo funktioniert nicht aus Basecamp: Hallo an alle, aus Kurviger habe ich Routen in meine Sammlungen geladen und von dort an mein Garmin gesendet. Beim Importieren auf meinem Gerät...
  • Karten vom Garmin Zumo XT auf Basecamp
    Karten vom Garmin Zumo XT auf Basecamp: Hallo zusammen, nach einem wechsel des Laptops ist Basecamp auf dem Neuen blank, d.h. keine Karten mehr darauf installiert/hinterlegt. Jetzt...
  • Karten vom Garmin Zumo XT auf Basecamp - Ähnliche Themen
