Fork oil level - why spacer in?
Diskutiere Fork oil level - why spacer in? im F 650 GS, F 700 GS und F 800 GS Forum im Bereich Motorrad Modelle; Does anyone happen to know why, for the F650GS, the BMW procedure to set the 100 mm air gap for the front forks requires that the spacer (only) be...
Okanagan
Does anyone happen to know why, for the F650GS, the BMW procedure to set the 100 mm air gap for the front forks requires that the spacer (only) be installed in the fork leg? Why didn't BMW simply specify a larger gap without the spacer installed?
The spacer is hollow but it does displace enough oil to significantly raise the level.
Installing the spacer to measure the air gap means that you have to remove it once the air gap is set so that the spring can go in first. I have done this three times now so I know how and the procedure does work. But why this awkward procedure?
I have yet to see an explanation and I have certainly looked for one.
mgo
Whatever the reason, it definitely sounds very odd.
BMW Oil Invlusive VIN Abfrage: Guten Morgen,
Ich wüsste gerne ob die Ausstattungsoption
SA-NR: 7A1 für Oil Inclusive 50/5 bei einer VIN Abfrage einer 1250 GS als dem Fahrzeug...
41mm Fork Plug Removal Tool: The F650 and 700GS 41mm forks have plugs at the top that are under spring pressure and retained by a circlip-like retaining ring. The plug has to...
3x Castrol Fork Oil / Gabel Öl: Hi zusammen,
kann jemand 3x Castrol Gabel Öl gebrauchen? Hab ich mal gekauft, dann die Gabel aber doch in der Werkstatt revidieren lassen.
Steht...
Suche Obere Gabelbrücke BMW R1200GS Ab 2008 bis 2012 Fork Yoke: Bin auf der Suche Obere Gabelbrücke für BMW R1200GS Ab 2008 bis 2012 Falls jemand anzubieten hat bitte einfach Melden.
R80/100GS front fork mounted on R80G/S (TüV or BMW approval): Hi 2V riders
I have a BMW R80 G/S and would like to mount the front fork from a BMW R80/100 GS but I will need to have it certified for legal use...
Steht...
