BMW Motorrad Fehlercodes
Diskutiere BMW Motorrad Fehlercodes im Technik & Bastel-Ecke Forum im Bereich Modellunabhängige Foren; BMW Motorrad Fault Codes FAULT CODE,FAULT CODE DESCRIPTION,MODEL,SYMPTOMS,PROBLEM SOLVING REMEDY 10167 Output stage to...
I
igor2009
10167 Output stage to electric fuel pump GS/A 1200 Idling irregular
Battles to start
Fault appears to start intermittently
Bike may start and ride, then will
appear to have fuel starvation
This unit is situated on the
left side of the tank. It is a
little aluminium unit with
fins on. Check the o-ring
of this unit. Unscrew the
unit and check for
moisture in the cavity
below it. Use moisture
repellent spray and
contact cleaner to clean
this device.
If problem
solving does not
work then
replace the unit.
10218 CAN-Bus Timeout: No
communication with KOMBI
(Instrument cluster) control unit
GS/A 1200 Test with diagnostic
system.
Clear fault code.
10219 CAN-Bus Timeout: no
communication with ZFE (Central
vehicle electronics) control unit
GS/A 1200 Instrument cluster does not activate
properly.
Instrument cluster activates partially
and then fades away.
May start on intermittent occasions
system.
If all else fails
replace the ZFE
control unit.
(Very expensive).
10444 Fuse activated for component block
3 (starter relay, Immo (EWS) ring
aerial, ignition coils, injectors)
GS/A 1200 There may be a short on the battery
terminals or elsewhere. Can happen
in conjuction with fault code 10219.
23971 Rear wheel speed sensor: Signal
implausible
GS/A 1200 Possible dirt on sensor. Dirt on wheel
where sensor lost contact.
system.
Clear fault code.
Replace sensor if
fault code reappears.
24052 Electric System under-voltage GS/A 1200 Starter motor battles to turn
Instrument cluster fades and then
reappears.
Check Battery Voltage
Check that the alternator
is charging battery
Check wiring to see that a
short is not draining
battery power.
Replace battery if
it is not charging
or
Service alternator
24971 Pressure In Front Wheel Circuit To
High
GS/A 1200 Check Wheel Pressure! Release air out of front
wheel to the correct
pressure.
Clear Fault Code
25193 Internal Control Module Error -
Time out message ZFE_2
GS/A 1200 Not sure if there are any symptoms
but the fault code was not present
when diagnostics were performed.
Fault occurred possibly
due low voltage from the
battery at some stage
Clear Fault Code
25165 Internal Control Module Error -
Main processor reset due to under
voltage
Clear Fault Code
25193 Brake fluid level to low GS/A 1200 Check brake fluid levels, front and
rear reservoirs.
system.
Add brake fluid
and clear fault
code.
37641 Electrical System (KL30) under
voltage
41722 Park Light Open Circuit GS/A 1200 Park light could be faulty Check connections are
secure or replace bulb if
faulty.
Clear Fault Code
41724 Main High Beam headlight, open
circuit.
R1200RT Main high beam light could be faulty
or have a poor connection.
faulty.
Clear Fault Code
41726 Low Beam Headlight 1, open circuit. R1200RT Low beam headlight could be faulty
faulty.
Clear Fault Code
41729 Low Beam Headlight 2, open circuit. R1200RT Low beam headlight could be faulty
faulty.
Clear Fault Code
54104 CAN-Bus: No communication with
instrument cluster (Kombi) control
unit
GS/A 1200 This fault may occur in conjunction
with a faulty ignition.
system
Clear Fault Code.
288 Throttle Position Sensor, Internal
Fault on Upper or lower
Potentiometer Slider.
GS/A 1150 Rough Idling Measure Voltage,
optimum is around 0.36
volts.
Replace
potentiometer
and set at correct
voltage. Clear
fault code.
821 Hall Sensor 1, no signal - this fault
will always occur if engine is not
running or engine is not cranked
before reading fault codes.
GS/A 1150 Bike will not run. Replace sensor! Replace sensor if
fault code cannot
be cleared.
901 Hall Sensor 2, no signal - this fault
fault code cannot
be cleared.
17163 Front ABS motor defective. R1150RT ABS warning light flashing and no
power brake function... residual
braking only. Depending upon
whether front brake (lever) applied
or rear brake pedal... sometimes the
servo motor would race but no ABS
function.
It would be best to have
your nearest BMW agent
confirm your fault code.
Replace complete
ABS unit, which
will be very
costly. Clear fault
codes.
17433 Pressure in rear wheel cylinder to
low.
R1150RT Refer to fault code 17163 for details
on symptoms.
Replace complete
ABS unit, which
will be very
costly. Clear fault
codes.
277 Engine Coolant Temperature Sensor
Malfunction, Short circuit to earth
or temperature too low.
GS 650
Dakar
No coolant in system Check coolant system for
leaks. Check all hoses.
Check radiator cap. Check
water pump seal.
Replace coolant
sensor if
necessary. Clear
fault codes.
304 Oxygen (Lamda) Sensor Circuit
Malfunction, No signal or signal
intermittent.
GS 650
Dakar
Symptoms not openly evident. Bike
may be running rich.
Check and clean
connections on wire
harness.
If fault persists,
check or replace
lambda sensor.
Clear fault code.
309 Oxygen (Lambda) Sensor Heating
Circuit Malfunction, Signal
implausible
GS 650
Dakar
Irregular engine operation. Engine
will not function properly.
system. Reading should
alternate between 200mV
and 650mV.
Replace Lambda
sensor if
necessary. Clear
Fault Code.
821 Speed Sensor (rpm) GS 650
Dakar
Irregular speed reading on
instruments.
Clean sensor. Make sure
the wire is not damaged.
Replace sensor if
necessary. Clear
Fault Code.
1152 Cooling Fan Motor, signal
implausible.
GS 650
Dakar
Cooling fan does not work. Cooling
fan works intermittently on
activation. Will lead to overheating.
system whether the fan
works
Replace fan.
Clear Fault Code
821 Crankshaft encoder, short circuit or
open circuit.
G450X Symptoms not openly evident as bike
starts and runs.
The fault code was still
present.
Cleared Fault
Code. Fault did
not return.
1592 Steppermotor, throttle valve 2
defective
starts and runs.
present.
Cleared Fault
Code. Fault did
not return.
correct.
Tighten battery terminals.
Ensure good connection
on batter terminals.
Clear fault code.
23955 Front Wheel Speed Sensor: Signal
implausible.
system
Clear fault code.
Replace sensor.
BMW Motorrad Fault Codes - motorcycle manuals
*Text editiert kyrillische Schriftzeichen ersetzt*
qhammer
qhammer
Schön die Finger weg vom Link bevor das jemand gecheckt hat. :nein::nein::nein:
Othello
Othello
30km südwestlich von Stuttgart
R1200GS TÜ
Das URL des Links lautet: "http://motorcycle-repair-manual.jimdo.com/"
Die Homepage enthält für eine Unzahl von Herstellern download-bare Manuals oder Teilelisten.
Ich habe die Seite besucht (mit aktiviertem Norton Security), für mich sieht die Seite "gut" aus.
Die Info von Firefox sagt aus, dass die Seite unsicher sei, da keine Info über den Besitzer vorliegt und Daten nicht verschlüsselt werden.
Das allerdings ist bei den meisten privaten Homepages der Fall, so auch bei meiner eigenen.
Das ist KEIN Freibrief, und erst recht keine Aufforderung, diese Seite zu besuchen.
Aber für mich ist sie so sicher (oder unsicher) wie viele andere auch.
Dieselbe Unsicherheit wird z.B. auch bei der Seite: www.gs-forum.eu angezeigt ;)
Othello
qhammer
qhammer
Thx an die Mod's
BMW Motorrad Fehlercodes - Ähnliche Themen
  • Erledigt Suche Porta Telepass BMW Motorrad
    Suche Porta Telepass BMW Motorrad: Suche dieses kleine Porta Telepass Täschchen. Vielleicht hat noch jemand so eine rumliegen und braucht sie nicht mehr? Kontakt PN oder...
  • Erledigt BMW Motorrad Batterieladegerät 77 02 8 551 896
    BMW Motorrad Batterieladegerät 77 02 8 551 896: Ich verkaufe hier ein originales BMW Motorrad Batterieladegerät, das sich ideal für die Pflege deiner Motorradbatterie eignet. Preis 75€ zuzüglich...
  • Biete Bekleidung BMW Motorrad TourShell Textilkombi Gr. 48
    BMW Motorrad TourShell Textilkombi Gr. 48: Ich verkaufe hier meine BMW Motorrad TourShell Textilkombi in Größe 48, Motorradjacke, Motorradhose und herausnehmbarer Thermojacke. Die Kombi...
  • Biete R 1200 GS (+ Adventure) BMW Motorrad Adapter für Seitentaschen Atacama K50 K51 K81 K82
    BMW Motorrad Adapter für Seitentaschen Atacama K50 K51 K81 K82: BMW Motorrad Adapter für Seitentaschen Atacama K50 K51 K81 K82 25,-
  • Biete Sonstiges Motorrad Koffer Aufsatztaschen BMW 1250 GS
    Motorrad Koffer Aufsatztaschen BMW 1250 GS: 2x Kofferaufsatztaschen Wasserresistent Ähnlich diesem Produkt bei Amazon als Beispiel Amazon.de Beide Taschen sind wie neu, Reisverschlüsse sind...
  • Motorrad Koffer Aufsatztaschen BMW 1250 GS - Ähnliche Themen
